Have a UG ductbank with 28 each 6 inch conduits entering a manhole with 84 each 15 kV volt single conductors (3 cables per conduit) with 1.7 inch overall diameter of each single cable.
Need manhole dimensions required to meet requirements per NEC 314.71;
1) For a straight pull manhole
2) For an angle pull manhole at 90 degree cable routing however the 90 degree angle manhole cable does not have to be pulled in continuously at one time. The cable could be pulled in straight with a 200 foot tail outside the manhole and the remaining 200 foot tails pulled in at later 90 degree angle into the building.
