sathish kumar dhanasekaran
Petroleum
good morning sir
where i go to find the allowance of alignment out in vertical and horizontal pipes where is mentioned in section for example stainless steel line goes 10 meter height its plumpness is 5 mm out it is acceptable or not. and also project specification is not mentioned .. i am also referring section only i found the joint misalignment but i need a detail for plumpness or horizontal line out how many millimetre allowance its where mentioned in sections
thanking you
thanking you
