nxexplorer
Hello All,
I need help in journal for creating wcs and save it.
The journal will do format=> wcs==>orient=>CSYS of Object>select edge of cylinder, then save the wcs.
This is done in the work part of the assembly.
I need help, any suggest, and help is very much appreciated.
Recorded Journal(Codes):
' NX 1957
Imports System
Imports NXOpen
Module NXJournal
Sub Main (ByVal args() As String)
Dim theSession As NXOpen.Session = NXOpen.Session.GetSession()
Dim workPart As NXOpen.Part = theSession.Parts.Work
Dim displayPart As NXOpen.Part = theSession.Parts.Display
' Menu: Format->WCS->Orient...
Dim markId1 As NXOpen.Session.UndoMarkId = Nothing
markId1 = theSession.SetUndoMark(NXOpen.Session.MarkVisibility.Visible, "Start")
Dim origin1 As NXOpen.Point3d = New NXOpen.Point3d(0.0, 0.0, 0.0)
Dim normal1 As NXOpen.Vector3d = New NXOpen.Vector3d(0.0, 0.0, 1.0)
Dim plane1 As NXOpen.Plane = Nothing
plane1 = workPart.Planes.CreatePlane(origin1, normal1, NXOpen.SmartObject.UpdateOption.WithinModeling)
Dim unit1 As NXOpen.Unit = CType(workPart.UnitCollection.FindObject("MilliMeter"), NXOpen.Unit)
Dim expression1 As NXOpen.Expression = Nothing
expression1 = workPart.Expressions.CreateSystemExpressionWithUnits("0", unit1)
Dim expression2 As NXOpen.Expression = Nothing
expression2 = workPart.Expressions.CreateSystemExpressionWithUnits("0", unit1)
Dim origin2 As NXOpen.Point3d = New NXOpen.Point3d(0.0, 0.0, 0.0)
Dim normal2 As NXOpen.Vector3d = New NXOpen.Vector3d(0.0, 0.0, 1.0)
Dim plane2 As NXOpen.Plane = Nothing
plane2 = workPart.Planes.CreatePlane(origin2, normal2, NXOpen.SmartObject.UpdateOption.WithinModeling)
Dim expression3 As NXOpen.Expression = Nothing
expression3 = workPart.Expressions.CreateSystemExpressionWithUnits("0", unit1)
Dim expression4 As NXOpen.Expression = Nothing
expression4 = workPart.Expressions.CreateSystemExpressionWithUnits("0", unit1)
Dim origin3 As NXOpen.Point3d = New NXOpen.Point3d(0.0, 0.0, 0.0)
Dim normal3 As NXOpen.Vector3d = New NXOpen.Vector3d(0.0, 0.0, 1.0)
Dim plane3 As NXOpen.Plane = Nothing
plane3 = workPart.Planes.CreatePlane(origin3, normal3, NXOpen.SmartObject.UpdateOption.WithinModeling)
Dim expression5 As NXOpen.Expression = Nothing
expression5 = workPart.Expressions.CreateSystemExpressionWithUnits("0", unit1)
Dim expression6 As NXOpen.Expression = Nothing
expression6 = workPart.Expressions.CreateSystemExpressionWithUnits("0", unit1)
Dim origin4 As NXOpen.Point3d = New NXOpen.Point3d(0.0, 0.0, 0.0)
Dim normal4 As NXOpen.Vector3d = New NXOpen.Vector3d(0.0, 0.0, 1.0)
Dim plane4 As NXOpen.Plane = Nothing
plane4 = workPart.Planes.CreatePlane(origin4, normal4, NXOpen.SmartObject.UpdateOption.WithinModeling)
Dim expression7 As NXOpen.Expression = Nothing
expression7 = workPart.Expressions.CreateSystemExpressionWithUnits("0", unit1)
Dim expression8 As NXOpen.Expression = Nothing
expression8 = workPart.Expressions.CreateSystemExpressionWithUnits("0", unit1)
Dim unit2 As NXOpen.Unit = CType(workPart.UnitCollection.FindObject("Degrees"), NXOpen.Unit)
Dim expression9 As NXOpen.Expression = Nothing
expression9 = workPart.Expressions.CreateSystemExpressionWithUnits("0", unit2)
Dim expression10 As NXOpen.Expression = Nothing
expression10 = workPart.Expressions.CreateSystemExpressionWithUnits("0", unit2)
Dim expression11 As NXOpen.Expression = Nothing
expression11 = workPart.Expressions.CreateSystemExpressionWithUnits("0", unit2)
Dim expression12 As NXOpen.Expression = Nothing
expression12 = workPart.Expressions.CreateSystemExpressionWithUnits("0", unit1)
Dim expression13 As NXOpen.Expression = Nothing
expression13 = workPart.Expressions.CreateSystemExpressionWithUnits("0", unit2)
Dim expression14 As NXOpen.Expression = Nothing
expression14 = workPart.Expressions.CreateSystemExpressionWithUnits("0", unit1)
Dim expression15 As NXOpen.Expression = Nothing
expression15 = workPart.Expressions.CreateSystemExpressionWithUnits("0", unit2)
Dim expression16 As NXOpen.Expression = Nothing
expression16 = workPart.Expressions.CreateSystemExpressionWithUnits("0", unit1)
Dim expression17 As NXOpen.Expression = Nothing
expression17 = workPart.Expressions.CreateSystemExpressionWithUnits("0", unit2)
expression9.SetFormula("0")
expression10.SetFormula("0")
expression11.SetFormula("0")
expression12.SetFormula("0")
expression14.SetFormula("0")
expression16.SetFormula("0")
expression13.SetFormula("0")
expression15.SetFormula("0")
expression17.SetFormula("0")
expression12.RightHandSide = "0"
expression14.RightHandSide = "0"
expression16.RightHandSide = "0"
expression13.RightHandSide = "0"
expression15.RightHandSide = "0"
expression17.RightHandSide = "0"
theSession.SetUndoMarkName(markId1, "CSYS Dialog")
Dim cylinder1 As NXOpen.Features.Cylinder = CType(workPart.Features.FindObject("CYLINDER(0)"), NXOpen.Features.Cylinder)
Dim edge1 As NXOpen.Edge = CType(cylinder1.FindObject("EDGE * 1 * 3 {(262.999261610441,-144.9773743316356,50)(285.499261610441,-131.986993274869,50)(262.999261610441,-118.9966122181024,50) CYLINDER(0)}"), NXOpen.Edge)
Dim xform1 As NXOpen.Xform = Nothing
xform1 = workPart.Xforms.CreateXform(edge1, NXOpen.SmartObject.UpdateOption.AfterModeling)
Dim markId2 As NXOpen.Session.UndoMarkId = Nothing
markId2 = theSession.SetUndoMark(NXOpen.Session.MarkVisibility.Invisible, "CSYS")
theSession.DeleteUndoMark(markId2, Nothing)
Dim markId3 As NXOpen.Session.UndoMarkId = Nothing
markId3 = theSession.SetUndoMark(NXOpen.Session.MarkVisibility.Invisible, "CSYS")
Dim cartesianCoordinateSystem1 As NXOpen.CartesianCoordinateSystem = Nothing
cartesianCoordinateSystem1 = workPart.CoordinateSystems.CreateCoordinateSystem(xform1, NXOpen.SmartObject.UpdateOption.AfterModeling)
xform1.RemoveParameters()
theSession.DeleteUndoMark(markId3, Nothing)
theSession.SetUndoMarkName(markId1, "CSYS")
workPart.Expressions.Delete(expression12)
workPart.Expressions.Delete(expression14)
workPart.Expressions.Delete(expression16)
workPart.Expressions.Delete(expression13)
workPart.Expressions.Delete(expression15)
workPart.Expressions.Delete(expression17)
workPart.Expressions.Delete(expression9)
workPart.Expressions.Delete(expression10)
workPart.Expressions.Delete(expression11)
Try
' Expression is still in use.
workPart.Expressions.Delete(expression2)
Catch ex As NXException
ex.AssertErrorCode(1050029)
End Try
Try
workPart.Expressions.Delete(expression4)
End Try
Try
workPart.Expressions.Delete(expression6)
End Try
Try
workPart.Expressions.Delete(expression8)
End Try
Try
workPart.Expressions.Delete(expression1)
End Try
plane1.DestroyPlane()
Try
workPart.Expressions.Delete(expression3)
End Try
plane2.DestroyPlane()
Try
workPart.Expressions.Delete(expression5)
End Try
plane3.DestroyPlane()
Try
workPart.Expressions.Delete(expression7)
End Try
plane4.DestroyPlane()
Dim nErrs1 As Integer = Nothing
nErrs1 = theSession.UpdateManager.AddToDeleteList(cartesianCoordinateSystem1)
Dim objects1(0) As NXOpen.TaggedObject
Dim cartesianCoordinateSystem2 As NXOpen.CartesianCoordinateSystem = CType(workPart.FindObject("ENTITY 45 1"), NXOpen.CartesianCoordinateSystem)
objects1(0) = cartesianCoordinateSystem2
Dim nErrs2 As Integer = Nothing
nErrs2 = theSession.UpdateManager.AddObjectsToDeleteList(objects1)
Dim origin5 As NXOpen.Point3d = New NXOpen.Point3d(270.49926161044101, -131.98699327486901, 49.999999999999986)
Dim matrix1 As NXOpen.Matrix3x3 = Nothing
matrix1.Xx = 1.0
matrix1.Xy = 0.0
matrix1.Xz = 0.0
matrix1.Yx = 0.0
matrix1.Yy = -1.0
matrix1.Yz = 0.0
matrix1.Zx = 0.0
matrix1.Zy = 0.0
matrix1.Zz = -1.0
displayPart.WCS.SetOriginAndMatrix(origin5, matrix1)
Dim id1 As NXOpen.Session.UndoMarkId = Nothing
id1 = theSession.NewestVisibleUndoMark
Dim nErrs3 As Integer = Nothing
nErrs3 = theSession.UpdateManager.DoUpdate(id1)
theSession.CleanUpFacetedFacesAndEdges()
' Menu: Format->WCS->Save
Dim cartesianCoordinateSystem3 As NXOpen.CartesianCoordinateSystem = Nothing
cartesianCoordinateSystem3 = displayPart.WCS.Save()
' Menu: Tools->Journal->Stop Recording
End Sub
End Module
Best Regards
Maryadi
' NX 1957
Imports System
Imports NXOpen
Module NXJournal
Try
End Try
Try
End Try
Try
End Try
Try
End Try
Try
End Try
Try
End Try
Try
End Try
Try
End Try
matrix1.Xx = 1.0
matrix1.Xy = 0.0
matrix1.Xz = 0.0
matrix1.Yx = 0.0
matrix1.Yy = -1.0
matrix1.Yz = 0.0
matrix1.Zx = 0.0
matrix1.Zy = 0.0
matrix1.Zz = -1.0
End Sub
End Module
Best Regards
Maryadi
