Need Help: NX Journal to get layer category string of current work layer number. 1
nxexplorer
ID
Hi
I Need Help in NX Journal on how to get layer category name (string) of current work layer number.
Thank you,
Best Regards
MARYADI
The journal below will report the first category found for the current work layer. Note that a layer can belong to multiple categories, this journal only reports the first category found.
Code:
'NXJournaling.com
'June 23, 2016
'Return first layer category found of a given layer number
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Module Module3
    Dim theSession As Session = Session.GetSession()
    Dim theUfSession As UFSession = UFSession.GetUFSession
    Dim workPart As Part = theSession.Parts.Work
    Dim lw As ListingWindow = theSession.ListingWindow
    Sub Main()
        If IsNothing(theSession.Parts.BaseWork) Then
            'active part required
            Return
        End If
        lw.Open()
        Dim layerCat As String = GetLayerCategory(theSession.Parts.Work.Layers.WorkLayer)
        If IsNothing(layerCat) Then
            lw.WriteLine("layer does not belong to any category")
        Else
            lw.WriteLine("layer belongs to category: " & layerCat)
        End If
        lw.Close()
    End Sub
    Function GetLayerCategory(ByVal layerNum As Integer) As String
        'layerNum must be between 1 and 256 inclusive
        If layerNum < 1 OrElse layerNum > 256 Then
            Return Nothing
        End If
        For Each temp As Layer.Category In workPart.LayerCategories
            If temp.Name = "ALL" Then
                'skip the ALL category
                Continue For
            End If
            For Each categoryLayerNum As Integer In temp.GetMemberLayers
                If categoryLayerNum = layerNum Then
                    Return temp.Name
                End If
            Next
        Next
        'layer number not found in the existing categories
        Return Nothing
    End Function
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
        GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately
    End Function
End Module
www.nxjournaling.com
Hi Cowski,
This journal works like what I want.
Thank you very much.
Best Regards,
Maryadi
