NEED HELP WITH LIST ATTRIBUTES
Pat_db
Automotive
Aug 23, 2018
14
I have 2 attribute lists with drop down menus to set the value of each attribute.
I have one attribute called ITEM_TYPE and the second one called ITEM_TYPE_ID. Each value for ITEM_TYPE corresponds to a value for ITEM_TYPE_ID
When I select a value for ITEM-TYPE I need the value for ITEM_TYPE_ID to automatically change to its corresponding value to eliminate the chance of the ITEM_TYPE not matching the ITEM_TYPE_ID. How would I set that up using NX10?
