  • Congratulations waross on being selected by the Tek-Tips community for having the most helpful posts in the forums last week. Way to Go!
Need help
radekw
5
0
0
Could someone help me with modelling a solid round bar in sap? I tried meshed polylines and extruding a circular shell element area but nothing seems to work. Help is much appreciated.
So you're saying that you can't model steel rod buckling with residual stress using a frame element? Can you elaborate? Fyi, to define a solid rod as a frame element using Version 11, you have add new frame property for "concrete" type, then change material to steel.
Having said that, it appears that there is a bug or limitation in SAP in extruding a circular area to a solid. I hadn't tried it until you posted. I think there is a way to draw solids without extruding using open GL
