eex23
Industrial
- Dec 13, 2005
- 326
Hi all,
Please see attached model file. Having some problems with adding blend between two surfaces (showed in cyan color). The problem is, that blend should connect two curved surfaces in fixed radius (70mm). And also it must have constant width of 13mm. As you can see now, created solid does not fit well with curved areas. Tried to play with Face Blend, but with no success. So any help would be really appreciated.
Thank you.
NX10, 64bit
Win 7, 64bit.
Thank you.
NX10, 64bit
Win 7, 64bit.
