Peter Glus
- Apr 22, 2021
- 9
I have a small plate that I want to move up and down by turning a threaded rod. The plate is not thick enough to tap it, so I was doing some research and found sleeve nuts. However, i want the plate to hold forces up and down, and sleeve nuts seem 1 directional. Ideally, if they could make a 2 piece sleeve nut that locks onto the plate that would be ideal. Any help out there? This in advance
