Negative Temperature values due to friction between gears.
Sarikahirpara
29
I am trying to simulate temperature increase due to friction in a gearbox. I am performing this analysis in coupled field transient so that i can apply rotation and friction between the gears but the problem is, in the temperature result, minimum values are going in negative values. I have attached result images for reference. Please help.
Thank You
Sarika Hirpara
 https://files.engineering.com/getfile.aspx?folder=d41b92cc-ded5-4d47-97f5-7c488f18f792&file=Capture.PNG
