ronjon322
- Feb 18, 2014
- 16
I know this is not the best application but can anyone give me in short answer form if I can spec out a 3/4" X 9" stainless steel Nelson Stud to be welded to a 1/2" mild steel plate, in the field. Plate can also be 3/4" if that would help and stud could also be some other corrosive material but would prefer stainless for direct weather exposure. No strength required. This is a very static system experiencing little or no loads on the studs.
Looking for an easy application, contractor will have to do a couple hundred of these.
Ronnie
Measure twice, cut once.
Ronnie
