I have 4 loads on a structure. For example like a Truck experiencing loads from 4 tires. The 4 loads can vary from -26 lbs to +32 lbs in z direction. I want to analyse all load cases at every 2 lbs increment. How do I set up the load case for Inertial Relief? This is NOT a time step. I want to figure out the worst possible combination of loads.
