Hello all. I'm working a project bound for outer space that has fracture requirements associated with it (NASA-STD-5019). One of these I'm trying to show for my parts is to show "parts have total net-section stresses, e.g., maximum principal or von Mises, whichever is larger, at limit load that are less that are less than 30 percent of the ultimate strength." I've got a finite element model of my assembly that I'll be using to determine what these net section stresses are. There is further explanation later in the section on how to calculate this with a FEM: "For metallic parts addressed in item 6.2.5.a (above), the net-section stresses are to be computed based on strength-of-materials theory. An example of the net-section stress calculation for combined tension and bending stress is detailed in the NASGRO® User’s Manual, Appendix B, in the beginning pages, except no crack or epsilon factor is used for this NFC low-risk application. For complex parts where finite element results are obtained that may include stress concentrations and stress gradients, the net-section stresses are to be computed by integrating the stress distribution and dividing by the area for the sectional area being assessed."
My question is this: how do I treat net section bending stresses? (I've ordered NASGRO, but don't have it yet to know how to do the combined tension and bending stress per their example.) As a simple example, suppose I have a fixed cantilever beam that is FE modeled. If I apply a transverse load at the tip, I'll get stresses due to a bending load on the outer fiber, one side in tension and one in compression. The stress distribution across the net section is assumed linear (although not true), but safe to say there is a region of tensile stress down to the neutral axis and the same for compression. If I take the integral of the stress over this area, it will give me a net stress of zero. I can think of a few ideas on the appropriate way to treat this but wanted to get your thoughts. 1) If I use von Mises stress, it is always a positive quantity, so the net section stress will be positive if using both tensile and compressive stresses. 2) I could use max principal, but need to use the absolute value of stress. 3)I only look at the tensile stress over the tensile stress area and disregard the compressive stress area.
Thanks for your help. I've been mulling this over for weeks and its finally time to tackle the analysis.
