Shamas javeed
Good evening everyone
Dear I have a genset connected with hydel turbine having terminal voltage 380v and 860kw capacity.
The neutral (star point) is not connected to the ground.
What should I do to connect the neutral to the ground??
Ngr?
Magnetic contractor ?
Direct grounding??
I will be thankful
Ngr?
Direct grounding??
I will be thankful
