I am working on the design of a ADU (accessary dwelling unit) in the backyard of a main house.
They want to tear down the existing 1 story ADU superstructure (but leave the existing concrete slab on grade foundation) and build a new 2 story ADU wood framed structure on top.
The original ADU was built in 1950ish, so, no idea about the foundation construction quality or design, except that it is a concrete slab that appears to be in decent condition.
My principal says he will not sign off on the existing foundation. The owner is wondering if they can "sign off on it", or, if you will, assume the liability for any future issues that were a result of the moving foundation.
Is this a legal option? If this was, for example, a steel beam, we obviously would not let an owner sign off on something that was 50% undersized, however, for a concrete foundation, I feel like most or all of the issues that could arise would not be life threatening and more of an aesthetic nature.
In the IEBC (International Existing Building Code)it says that any structural element carrying more than a 5% increase in loads shall be brought up to code, essentially. So, checking the code, the IRC references the IBC which basically says that foundations shall be designed such that deflections and racking of the supported structure (due to expansive soils) shall be limited to that which will not interfere with the usability and serviceability of the structure.
I'm not aware of anything in the code that allows (or disallows) an owner to assume liability for excessive "serviceability" issues.
Thoughts?
Thanks in advance.
Matt
Thoughts?
Thanks in advance.
Matt
