JStructsteel
Working on a design for new CMU elevator shaft in a existing brick building. Concrete slab floors. How would you anchor to the existing building? Its in a corner, so on two walls its against the existing brick. Was thinking here just some brick ties at an interval.
At the slab sides, was thinking a angle to the underside of the floor and anchor into a bond beam at the block. Bond beam would be all 4 sides to distribute the load.
Thoughts? 4 Stories, approx 50' tall
