Dear mates,
A pressure vessel was designed and built in accordance with ASME VIII - Div. 1, a year later it was decided to put it into service and it was discovered that the water left inside the vessel as a result of the hydraulic test generated serious damage by corrosion inside it. and they must be repaired by placing patches inserted.
The question is under what code should I perform this major repair, can API 510 be applied?
Thanks.
Thanks.
