rmillercwi
Materials
- Jul 19, 2006
- 76
I am assisting with a grade 91 tube leak on an older HRSG built in the late 90's. T-91 tube, grade 91 header. Failure at the toe of the weld. Failure cause and weld repair process understood.
The repair tube stub is cold bent. A PG-20 strain calc steers us into heat treatment of the bend after bending but no normalizing allhough I have been involved in repairs that both heat treatment and normalizing was required.
The question is do we really have to do this heat treatment/normalizing on boiler repairs when the requirement for doing so did not exist during original fabrication? I was involved with a large amount of fabrication of this type back in the late 90's to mid 2000's and dont ever recall this requirement.
I certainly understand the requirement for new construction. I struggle to understand the requirement when many boiler tubes on either side of the repair did not have this performed.
Same with tube repairs of T-23 material. Back in the day many boiler harps were made of material to earlier code cases (many to 2199-3) and I think now its up to 2199-8 makeing stock of earlier sourced material un-useable.
Perhaps there is an exemption that allows fabrication/use of materials to original code addenda?
