New to Abaqus. Please help me with my tie constraints and other errors.
hilander009
Computer
Jul 23, 2020
5
I am trying to model an actuator that looks something like this (excluding the caps) which is inspired by this fibre-reinforced actuator. I have also written a python script to do the same but I am getting the following error :
Python:
Error in job myjooob: The following sets were not found when generating the surface "fibers-2_FiberSet 2_CNS_": FIBERS-2."FiberSet 2"
Error in job myjooob: in keyword *SURFACE, file "myjooob.inp", line 53059: Unknown part instance node set FIBERS-2."FiberSet 2"
Error in job myjooob: NODE SET ASSEMBLY_FIBERS-2_FiberSet 2 HAS NOT BEEN DEFINED
Error in job myjooob: THERE IS NO DATA ASSOCIATED WITH *SURFACE, NAME=ASSEMBLY_fibers-2_FiberSet 2_CNS_, TYPE=NODE. NODES OR NODE SETS ARE REQUIRED.
Error in job myjooob: THE SLAVE SURFACE ASSEMBLY_fibers-2_FiberSet 2_CNS_ DOES NOT EXIST.
Job myjooob: Analysis Input File Processor aborted due to errors.
Error in job myjooob: Analysis Input File Processor exited with an error.
Job myjooob aborted due to errors.
which leads me to believe that there is something wrong with my tie constraints.
These are the steps that describe my work:
1. Inner First Circle
2. Inner Second Circle
3. Extrude
4. Outer First Circle
5. Outer second Circle
6. Extrude
7. adding tube I as an instance
8. adding tube II as an instance
9. merging instances to make merged actuator
10. create point for fiber I
11. running fibers script (to make helix)
12. create point for fiber II
13. running fibers script (to make helix II)
14. Add fibers I and II to assembly
15. adding fiber I and II instance
16. DEFINE elastosil material
17. DEFINE kevlar material
18. creating elastosil sections (for tube I)
19. creating elastosil section II (for tube II)
20. creating kevlar/fiber section (for fiber I)
21. creating kevlar/fiber section II (for fiber II)
22. assigning sections for merged actuator
23. assigning sections for fibers
24. beam section orientation for fiber I and II
25. create inner surface for tube I
26. create outer surface for tube II
27. create step
28. Boundary conditions (??????)
29. Amplitude
30. Apply load
31. mesh control
32. mesh element type
33.. set seed
34.. mesh generation
35. mesh fibers
36.. mesh settings for fibers
37. mesh
38. tie constraint for fiber I and tube I (outer surface)
39. tie constraint for tube II (outer surface) and fiber II
Any recommendations are appreciated
The problem is not with tie constraints itself but rather with surfaces needed for these constraints - they are not defined properly by the script. Check the parts of the code responsible for that.
