Designer 82,
That decision is TOTALLY up to the registered architect and NOT a sprinkler designer.
Here is how I see it working.
I am a NICET IV and have been designing systems for nearly 50 years now, my first NFPA #13 was 1974, and if I have learned anything it is that I am NOT an architect.
I have seen some designers get into the worst trouble ever because they thought since they were good at designing sprinklers they should know the building codes and should be able to decide when a building needed sprinklers and if it was NFPA #13 or 13R. Nothing is farther from the truth.
I know a single story motel that ended up requiring a full NFPA #13 system because it had something to do with means of egress and distance to the door. That isn't my call that's the registered architect for the project.
Does the architect know how to design sprinkler systems? Very, very, very few do but that isn't their job that's your job. Same thing goes on who decides what what standard to use. Do we use NFPA #13 or 13R? That is NOT your call that is the call of the registered architect for the project. Depending on where you are located things can come into play such as distances from adjacent buildings and lot lines.... something you, as a sprinkler system designer, aren't expected to know but the registered architect sure is.
When I get a set of architectural drawings where we could be looking at a NFPA $13R system I look at the drawings to find EXACTLY what the architect of record says it should be because, as the registered architect of record, that is HIS job and not mine!
If it is not on there I ALWAYS ask the architect of record and I let him tell me, in writing, what standard I should use. I get it in writing and at that point that is my get out of jail free card.
OK, let's say the architect of record wants sprinklers in that portion of the attic. Is it right or wrong? I honestly don't know maybe the architect of record decided he will put of some rated walls to enclose just that section of the attic? Maybe, maybe not and that is not your decision to make.
I had a job about six years ago where the architect of had on the drawings NFPA #13R with his seal and signature. I wasn't sure if it was right but my gut told me it was a full NFPA 13 system but... I wasn't the architect of record and when I start making decisions based on the building code look at it as I am playing architect without a license which is illegal in every state I am familiar with. Job was almost completed when the state fire marshal came up and labeled the job a full NFPA #13 system. What a disaster. We had to run 800' of 8" line to a hydrant in front of the building with a put and you name it. With a 13R system we had a 4" line we could have tied into but.... this job went from $50,000 to $250,000 overnight!
To decide what standard to follow was not my decision to make and I am glad as heck I never made it.
We designers don't follow building codes we follow STANDARDS as that is our job with the architect following the building code.
Building code doesn't tell us how it simply tells us the standard to follow. Let the architect do his job as the expert and tell you what standard to follow.
Sorry I got kind of wild on this but it is a lesson I have learned by watching disaster strike others.
A four story apartment building in Atlanta. Well, sounds to me like a #13R system but it wasn't because of some things beyond our scope of expertise (are there any registered architects reading this?) and that four story apartment building was a full NFPA #13 system. The bad part of this is the job was 95% completed and the architect never put on his drawings the standard to follow so the sprinkler contractor stupidly made that decision himself. Well, aren't we all supposed to be experts in sprinklers? Yes, we are but that is NFPA standards and not the building code.
Make the architect tell you what you need to do and that standard to follow. Get it in writing even if it's just an email because that could be your get out of jail free card.
Sorry everyone, I got carried away a bit.
