SprinklerDesigner2
My first hydraulic placard went was attached in 1976 and while I haven't seen it I doubt very much it is still there or, if it is, it's legible. Over time magic markers bead up or just fade away.
So the sign shall be inspected but what if it isn't there? The appendix reads I should go survey the system but that is the appendix and not the standard.
A survey wouldn't be that bad unless the pipe is concealed but then what?
How does your company treat it, if the sign is missing does their system get a green tag?
NFPA 25 2013 Handbook said:5.2.6* Hydraulic Design Information Sign. The hydraulic design information sign for hydraulically designed systems shall be inspected quarterly to verify that it is attached securely to the sprinkler riser and is legible.
A.5.2.6 The hydraulic design information sign should be secured to the riser with durable wire, chain, or equivalent. (See Figure A.5.2.6.)
Paragraph 5.2.6 requires that the hydraulic design information sign (also called a nameplate or placard) be inspected on a quarterly basis. NFPA 13 requires a hydraulic design information sign on hydraulically designed systems so that the design criteria and system demand can be readily determined. The hydraulic design information sign can provide useful information to the owner. If the design information sign is missing, the owner should contact a design professional to determine the demand for the system, which can be written on a new design information sign. The details are also documented on the approved plans and hydraulic calculations, but these plans can be misplaced and may not be available when the property changes owners. A hydraulic design information sign that is securely fastened to the riser can provide the details when these other data are missing (see Exhibit 5.21). If the sign becomes loose or is difficult to read, it must be repaired or replaced.
