I am purchasing an older single floor warehouse building that has had several addons over the years. The original building has its roof trusses parallel to the cmu walls with steel posts located centrally throughout the building every 14 ish feet. I believe the exterior walls are NLB with only a half dozen steel beams intersecting the CMU walls where the posts are located in the building. Posts being the support for the roof.
If I was interested in removing the central posts and installing a new roof that used the exterior CMU walls for their support. Is this possible? I would want to have a deck on the new roof that supported a hot tub with a maximum load of 150lb/sqft. Do they manufacture flat steel roof trusses to support that span (28 ft) and that load?
Thanks.
Thanks.
