It is equal to the boiling point, which from memory is just under 400F. Boiling point varies with pressure. You can get that from the vapor pressure curve.
For a pure component, one single species, condensing temp. = boiling temp. Commercial NMP may have a lot of cats and dogs in it, so it may have a boiling point range and a condensing temperature range. You need specific data on this.
Good luck,
Latexman
To a ChE, the glass is always full - 1/2 air and 1/2 water.
Actually, I'm selecting a coil to reduce the temperature of the exhaust, air mixed with 5% of NMP, i know the entering temp is 70F and out is 52F, i need to know when will condensate started, in order to select the coil properly.
thank you all, actually this is first time for me and probably i need more help on that.
You want the "dew point" of air mixed with 5% NMP. The moisture in that air could sway the results drastically, depending on the source of air, the % RH, and how it is or isn't treated. Just fyi.
Good luck,
Latexman
