jmramos
- Apr 26, 2020
- 11
Hello fellows,
The issue is that I can't see rebar detailing on some walls stacks, although on others they are represented without any problem. In particular, the detail of the retaining wall in the basement is shown without any problem, but not the rebar detailing of the walls of the elevator shaft. Although the forces and reinforcement report is generated for all stack walls.
Thanks in advance
Thanks in advance
