Node number update
SM1994
Bioengineer
Mar 25, 2020
49
Dear all
I am using python to generate a shape that the thickness and mesh size of it and hence the node number of it changes by each job.
I want the displacement of a specific part of geometry (attached), but I`d prefer to find a code or a solution that Abaqus automatically find the path for each job.
at the moment I manually select the nodes to create a path, but I want to find a way that code finds the nodes and creates that path automatically.
 https://files.engineering.com/getfile.aspx?folder=e2f59c65-b80f-48aa-a67a-188cf387ea42&file=abaqus1.png
Path can be also defined based on point coordinates (these are independent of the mesh density). To create a path with Python script you just have to use session.Path object and specify type as well as the list of nodes/points.
