jones1234
- Nov 17, 2019
- 4
I want to understand effect of washer thickness on bearing stress generated on clamping plate. What if I reduces washer thickness to half then will it increase the bearing force on plate ?? To accommodate this reduced washer thickness should bearing area needs to be increased ? Is there any calculation to justify washer thickness ? Which areas should be considered when you're reducing washer thickness ? Please note that this is for non-standard square washer.
