Nonlinear Analysis using ETABS
Vinduff
5
I am doing a nonlinear push-over analysis using ETABS, I defined a concrete element with elastic properties + nonlinear stress-strain curve (calculated using other formulation, rather then that of Mander used by default in ETABS). and I want to consider the nonlinearity of the material in a pushover analysis. How can I make ETABS to consider the material nonlinearity of concrete without assigning hinges to the element (the material properties of the element is concrete)?
