When I am in part designer, and I do a NORMAL VIEW on a surface or plane....it works fine, I can see my normal view....For example, I click on NORMAL VIEW, and then on the XY plane, and it goes to the parallel view, but the X-AXIS, for example, is not aligned at 0 degrees...it always seems to be off at some angle. Like, my whole part is tilted at an angle...How can I correct this?
Max...
maxshiff@sympatico.ca
Max...
