I'm currently on a project that has a subgrade issue that was not addressed and covered with Base. Six inches of Recycled Class II Base was moisture conditioned and compacted. The density results over the pumping areas were allegedly 95%+. However in my experience, it's sometimes possible to obtain passing tests and still have a pumping grade. I suggested that we proof roll it with a loaded water truck. And guess what, it was badly deflecting. This is to be an ally with heavy traffic. The structural section is six inches of Base and ten inches of 560C 3250 psi concrete (no steel). Should the concrete be placed over this pumping area without stabilizing it?? It should be noted, we are not pumping this concrete and loaded concrete trucks will be driving over this grade the day of the pour making it much worse. I suggested hogging out some of the base and increasing the concrete section to 12+ inches. Any thoughts would greatly be appreciated. Thank you
