I know that I may be searching for a non-existent answer, but I have to ask. In lieu of a customer’s specification for a nozzle load, what should a vessel supplier use for this calculation?
It has been a practice for some suppliers to use nothing. I think that this is a just ignoring the problem so that it goes away. Thermal reactions, PRV shock and other loads must be considered by UG-22.
If the supplier is mounting a PRV on top a vessel, I expect that supplier to properly support the PRV to handle the side loads generated or derate the flange for this load. If I am mounting this PRV, them it is my responsibility to specify the side loads to the vessel supplier.
For other piping connections, it is not so straight forward. You can strategically place pipe supports to minimize the loads, but you can never eliminate them. That being said, what loads should be used in the calcs?
Chris Foley
Midland, TX
Chris Foley
Midland, TX
