mechengineer
- Apr 19, 2001
- 265
Nozzle thrust load is an old topic. I think that thrust load cannot exist independently without internal pressure. The connection of the nozzle to the shell has been evaluated based on the internal pressure and reinforcement. In other words, the so-called "thrust load" has been considered in the internal pressure analysis for reinforcement (opening local stress). If there is no pipeline connecting the nozzle and the nozzle with blind flange, the thrust load still exists, do you need to check the thrust load?
Therefore, if it is 1, the nozzle meets the reinforcement requirements under the internal pressure. 2. the external load of the nozzle from the pipeline meets the requirements of WRC 297, the local stress at the connection between the nozzle and the shell should be no issue.
For high pressure and thicker wall, the local stress at the nozzle to the shell joint will be controlled by the internal pressure and the local stress caused by the external load of the nozzle will be at a lower level.
