I would like to know if NPSH is a factor in submersible pumping applications?
We have a hydraulically driven centrifugal pump that has been converted to a submersible pump, the pump curve indicates the required NPSHr but this data is for a standard centrifugal application.
Am i right in thinking that only the minimum submergence calculation is applicable?
Cheers
Cheers
