Dear All,
We are installing a vertical turbine fire pump as NFPA 20 and we are providing the required submergence as required by NFPA 20.
We know that NPSH is an important consideration in pump selection.
I did not provide vendor NPSHa and neither I asked vendor about NPSHr.
I was told that NPSH is not applicable to fire pumps as long as we provide the required submergence.
Do I need to specify the pump NPSHa and compare it with NPSHr from Vendor? Did I make a mistake by following this ?
Please provide your comments.
Please advise where does NFPA 20 talk about NPSH for vertical turbine pumps?
