I have a fundamental question regarding NPSHA of condenser pumps (open circuit), in short, the formula, absolute pressure above liquid surface ± Suction Static - Friction Loss - Vapor Pressure. This is applicable prior to recognizing available NPSH before selecting the pump. My question comes after running the pump with suction gauge pressure. the way I understand to find the NPSHA after running the pump, gauge suction pressure +atmospheric pressure-vapor pressure. I found in some articles and YouTube videos that state adding the elevation pressure and friction head. Then formula defines like, absolute pressure + elevation +suction friction loss-vapor pressure. Is the suction pressure sum of the elevation and the friction loss? Then, why again add the elevation and friction head with suction pressure. It makes confusion. I think you can grasp my question?
