I am bit confused on the NPSHA calculation. The equation I am using is this:
NPSHA = Ha +/- Hst - Hf - Hvp
Where,
Ha = ambient pressure
Hst = static head from liquid surface to pump centerline
Hf = friction loss a entrance through piping/fittings
Hvp = vapor pressure
Ok, so I know on suction lift stations, the Hst value is the distance from the water level in the WW to the pump centerline, which is a negative value.
My question is this: on a submersible station, is the Hst value still the distance from the water level *in the WW* to the pump centerline or is it the static head (WW water level to discharge water level)?
Thanks!
Where,
Thanks!
