Hi all,
I have a couple pumping questions below.
Is it necessary to check the available net positive suction head for a submerible pump that is designed to run dry?
Is vapour pressure only a function of temperature? What about elevation? I have been working on pumps for underground applications but I have a hard time determining liquid vapour pressure and atmospheric pressure underground.
I'm working on another project pumping fuel, and its difficult to find specifications on engineering data. Is there any "bible" literature of liquids that contains engineering data only? (eg specific heat, vapour pressures, sg, etc)
J
J
