Fabian Antao
Industrial
- Feb 4, 2022
- 2
We have three pumps. The size of the NRV is 600mm. The pumps are operated with Soft Starter.
When first commissioned the pumps, the pumps operated fine.
The NRV's lifted completely and there would be a pressure reading of 0.8 bar.
Now into, 3 months of opeartion, the NRV's are not lifting when the pump is ON.
The pressure shown on the pressure guage is 2.0 bar. Pressure gauage is positioned after the discharge valve. (Pump --> NRV ---> Disharge Valve--> Airvalve)
We literally have to support the arm of the NRV, to OPEN it to full position.
All the three NRV's are behaving in a similar fashion.
This is causing low discharge flow from the pumps.
It's a three pumps system, 1 Duty, 1 Assist & 1 Stand by
Soft Starter is ABB (PSTX370-600-70)
Limit
Current limit type - Normal
Current limit level - 3.0 xle
2nd curr lim level - 7.0 xle
2nd curr lim time - 8 sec
Torque limit level - 150 %
Start & Stop
Start Mode - Voltage Ramp
Stop Mode - Voltage Ramp
Start ramp initial level - 30%
Start ramp - 5 sec
Stop ramp and level - 30 %
Would appreciate if someone could help me understand how to overcome this situation.
Thanks in advance.
Limit
Start & Stop
Start ramp - 5 sec
Thanks in advance.
