So far I have applied different methods which are usually long and impractical, besides having to make templates for each sheet type, because I when resize the sheet... the formatting is lost
I've seen some friends perform the same templates in Inventor and make it so much easier
In NX10, the title block will reposition automatically when the drawing border is changed, so if the sheet size changes, the title block will reposition.
From that I can't see why you can't make only one template for all possible sheets sizes.
