NX 11 Journal - 'Groups' of Associated Section Curves
jmarkus
CA
I've got a journal which creates a SectionCurve feature (multiple sections cut normal to a curve), with associativity turned on using SectionCurveBuilder. I would like to be able to identify the resulting groups of curves that _would have_ been created if associativity was turned off and I used the "Group Objects" option. Another way to look at it is that I would like to be able to identify curves belonging to each plane that was used for sectioning.
I don't want to turn associativity off, though, because I want the model to stay parametric for future changes. Each group in the section curve result would be a set of closed curves - if that helps.
How can I programmatically select these closed curve 'groups'?
Jeff
I suppose you could get the section planes and all section curves from the SectionCurveBuilder. Measure the distance between each curve and each plane. If the distance is zero(within modeling tolerance) the curves belong to that particular plane.
Suresh
I've thought about that. Since I'm interested in closed curves I've also looked at a routine that checks the distance between the end of one curve to the beginning of another. The concern I have with any of these methods is that they are intensive and the more curves I have, the longer it takes to sort them.
I was hoping there was some NXOpen functions that could identify the properties I am looking for...or even some way to capture the 'groups' while the SectionCurveBuilder is executing.
Jeff
I ended up modifying the code "SORT_SELECTED_CURVES_INTO_CHAINS.c" found on GTAC.
That worked for me!
Jeff
