dodbrew
- Aug 13, 2020
- 2
I am working on a sheet metal part in NX 12. When I export the part as a flat pattern, the dimensions in the flat pattern file is different from the original part file (brief example below). It shows the same behavior whether I use the Export function from the menu or simply Flat Pattern --> Export Flat Pattern from the home ribbon. Both dxf and dwg files are affected. I use eDrawings when control measuring, and Autodesk Viewer (online) confirms that the export is scaled up. However, importing the dxf flat pattern back into NX (resulting in *_dxf.prt filename) gives correct dimensions in the resulting part file.
Has anyone had this (or similar) before, and are there ways to address the issue? Thanks!
Example:
The sheet metal part has a few Ø9 holes (M8 clearance), and when I measure the exported file, these holes are now Ø228.6. Distances between holes are 3302 mm where they should be 130 mm. The entire flat pattern is scaled up by a factor of 25.4.
If scale factor is 25.4 it should point to issues with mm/inches, but I haven't found any settings that I can change to fix the issue.
Example:
