NX 1892 Density 3
CaptainCad
Automotive
Jun 2, 2011
15
Still using NX 1892 for now. I see that "Measure Body" is to be retired, I know that I can use the "Measure" command to get the mass of solid bodies. The problem is that it doesn't list the density so I can quickly verify it is correct. How can I display the current density of selected bodies without doing math?
Unless and until they change it, you can use information -> object (select your solid body) to get the density assigned to the body.
www.nxjournaling.com
This is great. I saw in the video I can turn on density in the Measure settings.
Adding a point at the center of gravity has changed. If you need help with that then be sure to let us know.
Jerry J.
UGV5-NX1899
