NX 1926 - Dimension Issue
BrittToolEngineer
Aerospace
Aug 4, 2016
239
Greetings:
I have a part nested into a fixture. I took a section view of the round assembly. When I go to dimension the fixture and the part, the dimension will not allow me to select say an endpoint on my part. I use to grab endpoints from components without issue in NX12 and earlier. I also did an intersection curve and put those lines in drafting. Those too are not selectable. Is there a check box that I need to turn on or off?
Brent
