I use NX1980/2000 to create parts books from drawing views. The problem is that almost all of our drawing views have dashed lines and I need to change them to solid lines.
Here is how I have been doing it-
1. Select an individual view
2. Right click and select "settings".
3. Choose "Visible Lines" and change from original (dashed) to solid lines.
4. Hit "ok" and it changes the lines in the view.
This works but it takes quite a while to do all of that to each drawing view. I tried selecting all views, but I can't find a way to change all the lines in all the views at once. I tried creating a macro to help speed up the process a little, but the macro gives me a playback error. I'm not sure how to make a journal to do this, so I'm stuck doing it the way I know.
Is there a faster way or at least a way to make a macro or journal to do this?
