NX 2212 - SKETCH message 2
CAD2015
Automotive
What is the meaning of the message shown in the Sketch environment (shown in the attached picture below)?.......
What option would be the most suitable?
Thank you!
You are adding the first dimension that will change the X length of the rectangle. It is asking if you want to scale the entire sketch, which will change the Y length to keep the same proportions the rectangle has now; or just change the X length, leaving the current Y length as it is now. This is more important with complicated initial sketches where a drastic dimension change can flip some of the geometry in an undesired way.
I usually press "yes", especially if the current dimension value is significantly different from my desired dimension.
