NX 8.5 - Assembly Component Name Change
ARToolingEngineer
Aerospace
May 11, 2021
52
Greetings,
I've created a couple of details that I named yyy.prt, then input those into my assembly. I now have to change the file name of the detail. Will my assembly keep relationship with the new file and drop relationship with the original?
BW
It will if you perform a "save-as" when the part and the assembly are open.
Open your assembly, make your desired component the display part and go to file -> save as. Enter a new name for your component file; NX will then ask if you want to save-as the assembly file as well, cancel this dialog and OK the overall operation. Your assembly will now reference the newly saved file, save the assembly to keep the change.
www.nxjournaling.com
