NX baseline files opening as Modified
mrtill01
7
I am having a issue in NX 11 I have a file that was baselined that when it is being opened opens as Modified even when this is the first part/assy opened in a session. Any ideas on how to fix this. I would think because this is a Baselined file it is a snapshot in time and should be opening the parts and revisions that were in the Assy when the part was baselined
Was the file last saved in an older version of NX (pre-NX 11)? Menu -> information -> part -> part history will show the save history. If so, the internal file structure is being updated to the NX 11 format when opened and shows as "modified". Your admin can use the "refile_part" utility to update older files to the new format.
www.nxjournaling.com
Are there wavelinks, promotions or interpart expressions?
These usually cause this behavior as well.
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
Building new PLM environment from Scratch using NX12 / TC11
