NX CAST 8
CaptainCad
Automotive
Jun 2, 2011
15
I have downloaded cast from GTAC site (CASTNX80Update64bit). Is it possible to install and run locally on a pc? I ran the setup and everything seemed to install correctly, but when i start the index file most of the links seem to be broken.
Did you purchase CAST and have a valid license?
Note that CAST was retired in 2012, and replaced with Learning Advantage.
Mark Rief
NX CAM Customer Success
Siemens PLM Software
That would explain it. I though CAST was included. I'll look into purchasing it,
Thank you.
