NX Drafting - Notes not showing on sheet
NaomiG
Hello!
I am using NX 2306. In the drafting application, I am trying to add a 'Note' to the sheet, but when I place the note, it does not show up. There is a symbol that shows beside the sheet (I have attached a screenshot), which I am not familiar with. Does anyone know what this symbol means? Or why the notes are not showing?
 https://files.engineering.com/getfile.aspx?folder=85203d95-02df-40ed-ba6f-b515e94a46aa&file=Capture.PNG
That symbol is new to me also.
Check that your work layer ( "Layer Settings" ) is visible on the sheet itself.( Layers visible in View) -select the Sheet and not any of the view-s.
You can also do "Information - Object , ( Ctrl+I) then select the sheet ( use part navigator for selection)
the visible layers will be listed as "Visible Layers".
Tomas
The more you know about a subject, the more you know how little you know about that subject.
Thank you for your response, Tomas!
This issue was resolved by restarting the PC.
