NX Fonts
jerry1423
3,428
Do all the fonts that are included with NX have a number associated to them?
for example blockfont is <F1>
I assume that the fonts that are numbered 1-14 are still that way, but the newer fonts do not have a number associated to them.
I am on NX6
It depends on the order in which the Fonts were added to your part file. Blockfont is always #1 since it's always there by default and therefore occupies the first 'slot'.
I would advice that if you're setting up a new system and there's a chance that you will need to use a consistent set of multiple fonts, that before you start to create parts, including any template parts, that you set-up the first 14 fonts using...
Customer Defaults -> Drafting -> General -> Lettering Fonts
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
On a similar thread,
Does anyone know if it is possible to create your own custom line fonts that are not based upon dots & dashes?
EG could a font be created to make a single line on a drawing / models really stand out by say making it a completely different style? A line of XXXXXX etc?
Cheers in advance
NXj
