skaboy607
- Dec 19, 2010
- 34
Hi
I have been trying to import a .dxf file. The initial import is fine and I then save it as a .prt. However when I add this to my assembly which is dimensioned in mm, the part is tiny compared to everything else. When importing the .dxf I have changed the default system from mm to m to inches but still, the part is tiny in my assembly.
Also, when it imports, you can't select and faces/edges or anything? Is there a way around this?
