Looking for any help here on this..
The code I have runs great in Native application of NX, but when ran in TeamCenter it errors out.
Quick run down of the code - it allows me to select a component, which then creates an attribute and let's you manually type in the value for that attribute.
With Native it looks like this:
With TeamCenter when I select it's giving me this:
Anyone know how I can troubleshoot this?
My code is provided below:
Code:
' WARNING!! This file is overwritten by the Block UI Styler while generating
' the automation code. Any modifications to this file will be lost after
' generating the code again.
' Filename: checkAttributes.vb
' This file was generated by the NX Block UI Styler
' Created by: vegetagaru
' Version: NX 9
' Date:
' Time:
' Purpose: This TEMPLATE file contains VB.NET source to guide you in the
' construction of your Block application dialog. The generation of your
' dialog file (.dlx extension) is the first step towards dialog construction
' within NX. You must now create a NX Open application that
' utilizes this file (.dlx).
' The information in this file provides you with the following:
' 1. Help on how to load and display your Block UI Styler dialog in NX
' using APIs provided in NXOpen.BlockStyler namespace
' 2. The empty callback methods (stubs) associated with your dialog items
' have also been placed in this file. These empty methods have been
' created simply to start you along with your coding requirements.
' The method name, argument list and possible return values have already
' been provided for you.
'These imports are needed for the following template code
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpen.BlockStyler
Imports System.Globalization
'Represents Block Styler application class
Public Class checkAttributes
'class members
Private Shared theSession As Session = Session.GetSession()
Private Shared theUFSession As UFSession = UFSession.GetUFSession()
Private Shared theUFSSession As UFSession = UFSession.GetUFSession()
Private Shared theUI As UI = UI.GetUI()
Private theDlxFileName As String
Private theDialog As NXOpen.BlockStyler.BlockDialog
Private groupAttr As NXOpen.BlockStyler.Group ' Block type: Group
Private UNIT_No As NXOpen.BlockStyler.StringBlock ' Block type: String
Private CYL_CODE As NXOpen.BlockStyler.StringBlock ' Block type: String
Private BLANK4 As NXOpen.BlockStyler.StringBlock ' Block type: String
Private BLANK3 As NXOpen.BlockStyler.StringBlock ' Block type: String
Private BLANK2 As NXOpen.BlockStyler.StringBlock ' Block type: String
Private BLANK1 As NXOpen.BlockStyler.StringBlock ' Block type: String
Private workPart As Part = theSession.Parts.Work
Private displayPart As Part = theSession.Parts.Display
Private lw As ListingWindow = theSession.ListingWindow
Private bodyPart As Part = theSession.Parts.Display
Dim theComponent As Assemblies.Component = Nothing
Dim MyPart As NXOpen.Part = Nothing
Dim resp1 As Integer = 0
#Region "Block Styler Dialog Designer generator code"
'Constructor for NX Styler class
Public Sub New()
' lw.Open()
If SelectComponent("select a component", theComponent) = Selection.Response.Cancel Then
Return
End If
' lw.WriteLine("component display name: " & theComponent.DisplayName)
' lw.WriteLine("component part path: " & theComponent.Prototype.OwningPart.FullPath)
' Const testAttribute As String = "thickness"
'Dim thicknessAtt As NXObject.AttributeInformation = Nothing
'If theComponent.HasUserAttribute(testAttribute, NXObject.AttributeType.Any, -1) Then
' thicknessAtt = theComponent.GetUserAttribute(testAttribute, NXObject.AttributeType.Any, -1)
' lw.WriteLine("""" & testAttribute & """" & " attribute found")
' lw.WriteLine(" attribute value: " & thicknessAtt.StringValue)
'Else
' lw.WriteLine("component does NOT have an attribute named: " & testAttribute)
'End If
' lw.Close()
MyPart = CType(theSession.Parts.FindObject(theComponent.displayName), NXOpen.Part)
Try
theDlxFileName = "R:\hms_tools\NX1872\Tooling\Journals\CYL_CODE_ATTR\Cyl Attributes.dlx"
theDialog = theUI.CreateDialog(theDlxFileName)
theDialog.AddApplyHandler(AddressOf apply_cb)
theDialog.AddOkHandler(AddressOf ok_cb)
theDialog.AddUpdateHandler(AddressOf update_cb)
theDialog.AddInitializeHandler(AddressOf initialize_cb)
theDialog.AddDialogShownHandler(AddressOf dialogShown_cb)
Catch ex As Exception
'---- Enter your exception handling code here -----
Throw ex
End Try
End Sub
#End Region
'------------------------------- DIALOG LAUNCHING ---------------------------------
' Before invoking this application one needs to open any part/empty part in NX
' because of the behavior of the blocks.
' Make sure the dlx file is in one of the following locations:
' 1.) From where NX session is launched
' 2.) $UGII_USER_DIR/application
' 3.) For released applications, using UGII_CUSTOM_DIRECTORY_FILE is highly
' recommended. This variable is set to a full directory path to a file
' containing a list of root directories for all custom applications.
' e.g., UGII_CUSTOM_DIRECTORY_FILE=$UGII_ROOT_DIR\menus\custom_dirs.dat
' You can create the dialog using one of the following way:
' 1. Journal Replay
' 1) Replay this file through Tool->Journal->Play Menu.
' 2. USER EXIT
' 1) Create the Shared Library -- Refer "Block UI Styler programmer's guide"
' 2) Invoke the Shared Library through File->Execute->NX Open menu.
Public Shared Sub Main()
Dim thecheckAttributes As checkAttributes = Nothing
Try
If check_for_missing_display_part() = 0 Then
thecheckAttributes = New checkAttributes()
' The following method shows the dialog immediately
thecheckAttributes.Show()
End If
theUI.NXMessageBox.Show("Check Attributes", NXMessageBox.DialogType.Error, ex.ToString)
Finally
If thecheckAttributes IsNot Nothing Then
thecheckAttributes.Dispose()
thecheckAttributes = Nothing
End If
End Try
End Sub
Function SelectComponent(ByVal prompt As String, ByRef selObj As TaggedObject) As Selection.Response
Dim resp As Selection.Response = Selection.Response.Cancel
Dim theUI As UI = UI.GetUI
Dim title As String = "Select a component"
Dim includeFeatures As Boolean = False
Dim keepHighlighted As Boolean = True
Dim selAction As Selection.SelectionAction = Selection.SelectionAction.ClearAndEnableSpecific
Dim cursor As Point3d
Dim scope As Selection.SelectionScope = Selection.SelectionScope.AnyInAssembly
Dim selectionMask_array(0) As Selection.MaskTriple
With selectionMask_array(0)
.Type = UFConstants.UF_component_type
.Subtype = UFConstants.UF_component_subtype
End With
'Dim resp As Selection.Response = theUI.SelectionManager.SelectTaggedObject(prompt, title, scope, selAction, includeFeatures, keepHighlighted, selectionMask_array, selObj, cursor)
resp = theUI.SelectionManager.SelectTaggedObject(prompt, title, scope, selAction, includeFeatures, keepHighlighted, selectionMask_array, selObj, cursor)
If resp = Selection.Response.ObjectSelected Or resp = Selection.Response.ObjectSelectedByName Then
Return Selection.Response.Ok
Else
Return Selection.Response.Cancel
End If
End Function
' This method specifies how a shared image is unloaded from memory
' within NX. This method gives you the capability to unload an
' internal NX Open application or user exit from NX. Specify any
' one of the three constants as a return value to determine the type
' of unload to perform:
' Immediately : unload the library as soon as the automation program has completed
' Explicitly : unload the library from the "Unload Shared Image" dialog
' AtTermination : unload the library when the NX session terminates
' NOTE: A program which associates NX Open applications with the menubar
' MUST NOT use this option since it will UNLOAD your NX Open application image
' from the menubar.
Public Shared Function GetUnloadOption(ByVal arg As String) As Integer
'Return CType(Session.LibraryUnloadOption.Explicitly, Integer)
Return CType(Session.LibraryUnloadOption.Immediately, Integer)
' Return CType(Session.LibraryUnloadOption.AtTermination, Integer)
End Function
' Following method cleanup any housekeeping chores that may be needed.
' This method is automatically called by NX.
Public Shared Sub UnloadLibrary(ByVal arg As String)
Try
End Try
End Sub
'This method shows the dialog on the screen
Public Sub Show()
Try
theDialog.Show()
End Try
End Sub
'Method Name: Dispose
Public Sub Dispose()
If theDialog IsNot Nothing Then
theDialog.Dispose()
theDialog = Nothing
displayPart.Views.Refresh()
theSession.Parts.SetWork(workPart)
Dim partCleanup1 As NXOpen.PartCleanup = Nothing
partCleanup1 = theSession.NewPartCleanup()
partCleanup1.TurnOffHighlighting = True
partCleanup1.DoCleanup()
partCleanup1.Dispose()
End If
End Sub
'Callback Name: apply_cb
Public Function apply_cb() As Integer
Dim response1 As Selection.Response = Selection.Response.Cancel
Dim errorCode As Integer = 0
Try
'---- Enter your callback code here -----
If UNIT_No.Value.ToUpper = "---" Then UNIT_No.Value = ""
If CYL_CODE.Value.ToUpper = "---" Then CYL_CODE.Value = ""
Dim theObjects(0) As NXObject
'theObjects(0) = bodyPart
theObjects(0) = theComponent
'createAttribute(myPart, theObjects, "UNIT_No", UNIT_No.Value)
'createAttribute(myPart, theObjects, "CYL_CODE", CYL_CODE.Value)
'MyPart.SetUserAttribute("UNIT_No", -1, UNIT_No.Value, Update.Option.Now)
'MyPart.SetUserAttribute("CYL_CODE", -1, CYL_CODE.Value, Update.Option.Now)
Dim attributePropertiesBuilder1 As AttributePropertiesBuilder
attributePropertiesBuilder1 = workPart.PropertiesManager.CreateAttributePropertiesBuilder(theObjects)
attributePropertiesBuilder1.ObjectPicker = AttributePropertiesBaseBuilder.ObjectOptions.Occurrence
attributePropertiesBuilder1.DataType = AttributePropertiesBaseBuilder.DataTypeOptions.String
attributePropertiesBuilder1.Title = "UNIT_No"
attributePropertiesBuilder1.IsArray = False
attributePropertiesBuilder1.StringValue = UNIT_No.Value
Dim nXObject2 As NXObject
nXObject2 = attributePropertiesBuilder1.Commit()
attributePropertiesBuilder1.Destroy()
Dim attributePropertiesBuilder2 As AttributePropertiesBuilder
attributePropertiesBuilder2 = workPart.PropertiesManager.CreateAttributePropertiesBuilder(theObjects)
attributePropertiesBuilder2.ObjectPicker = AttributePropertiesBaseBuilder.ObjectOptions.Occurrence
attributePropertiesBuilder2.DataType = AttributePropertiesBaseBuilder.DataTypeOptions.String
attributePropertiesBuilder2.Title = "CYL_CODE"
attributePropertiesBuilder2.IsArray = False
attributePropertiesBuilder2.StringValue = CYL_CODE.Value
Dim nXObject3 As NXObject
nXObject3 = attributePropertiesBuilder2.Commit()
attributePropertiesBuilder2.Destroy()
response1 = SelectComponent("select a component", theComponent)
errorCode = 1
End Try
apply_cb = errorCode
End Function
'Callback Name: ok_cb
Public Function ok_cb() As Integer
Try
'errorCode = apply_cb()
errorCode = 1
End Try
ok_cb = errorCode
End Function
'Callback Name: update_cb
Public Function update_cb(ByVal block As NXOpen.BlockStyler.UIBlock) As Integer
Try
If block Is UNIT_No Then
'---- Enter your code here -----
ElseIf block Is CYL_CODE Then
End If
End Try
update_cb = 0
End Function
'---------------------Block UI Styler Callback Functions--------------------------
'Callback Name: initialize_cb
Public Sub initialize_cb()
Try
groupAttr = CType(theDialog.TopBlock.FindBlock("groupAttr"), NXOpen.BlockStyler.Group)
UNIT_No = CType(theDialog.TopBlock.FindBlock("UNIT_No"), NXOpen.BlockStyler.StringBlock)
CYL_CODE = CType(theDialog.TopBlock.FindBlock("CYL_CODE"), NXOpen.BlockStyler.StringBlock)
theSession.Parts.SetWork(displayPart)
End Try
End Sub
'Callback Name: dialogShown_cb
'This callback is executed just before the dialog launch. Thus any value set
'here will take precedence and dialog will be launched showing that value.
Public Sub dialogShown_cb()
Try
UNIT_No.Value = readAttribute(MyPart, "UNIT_No")
If UNIT_No.Value = "" Then UNIT_No.Value = "---"
CYL_CODE.Value = readAttribute(MyPart, "CYL_CODE")
If CYL_CODE.Value = "" Then CYL_CODE.Value = "---"
End Try
End Sub
'Function Name: GetBlockProperties
'Returns the propertylist of the specified BlockID
Public Function GetBlockProperties(ByVal blockID As String) As PropertyList
GetBlockProperties = Nothing
Try
GetBlockProperties = theDialog.GetBlockProperties(blockID)
End Try
End Function
Public Shared Function check_for_missing_display_part() As Integer
Dim dispPart As Part = Nothing
dispPart = Session.GetSession().Parts.Display
If dispPart Is Nothing Then
Dim style As MsgBoxStyle
Dim title As String = "Check for Displayed part"
style = MsgBoxStyle.Information
MsgBox("There is no displayed part ", style, title)
Return 1
Else
Return 0
End If
End Function
Private Function readAttribute(ByVal selPart As Part, ByVal attrName As String) As String
Dim attrValue As String = Nothing
Dim iRes As Integer
Dim attrInfor As NXOpen.NXObject.AttributeInformation = Nothing
Dim attrtype As NXOpen.NXObject.AttributeType = NXObject.AttributeType.String
theUFSession.Attr.FindAttribute(theComponent.Tag, 5, attrName, iRes)
If iRes <> 0 Then
'attrInfor = selPart.GetUserAttribute(attrName, attrtype, 2)
attrInfor = theComponent.GetUserAttribute(attrName, attrtype, 2)
attrValue = attrInfor.StringValue
Else
attrValue = "---"
End If
Return attrValue
End Function
'User Functions
Private Sub createAttribute(ByVal thisPart As Part, ByVal theObjects() As NXObject, ByVal attrTitle As String, ByVal attrValue As String, Optional attrCategory As String = "")
Dim attributePropertiesBuilder1 As AttributePropertiesBuilder = theSession.AttributeManager.CreateAttributePropertiesBuilder(thisPart, theObjects, AttributePropertiesBuilder.OperationType.Create)
attributePropertiesBuilder1.Category = attrCategory
attributePropertiesBuilder1.Title = attrTitle
attributePropertiesBuilder1.StringValue = attrValue
End Sub
End Class
